Transmission Filter
Transmission Filter
I bought atp filter kit from Rockauto and the filter does not have a pickup tube like the one I removed, but slot in the side of the housing for oil entrance. Coventry West, on the other hand, shows a tube on their filter.
Should I toss the atp unit and order from Coventry West?
I made the same mistake, the other way around. Fortunately, my brother was able to use it on his Range Rover.
JP
Yes, cornering was my concern. The correct filter is arriving today and I have advised Rockauto of the problem.
Owners of X300 series should note that rockauto.com does not stock the correct transmission filter.
I think one of the mods could mark this thread RESOLVED.
Thanks all for your assistance.
Will I have same issue?
I ordered a Fram FT1076 for my North American 1997 XJ6 from RockAuto.
FRAM's website says this is what I should use.
Part Details
I have yet to remove the old filter and compare. Will I have the same issue?
Knowing now will save me downtime on the car!
Thank you very much.
Part Details
That looks like the one I threw away. This one from motorcars has the pickup.
http://www.motorcarsltd.com/jaguar/x...ission-filter/
trevc (11-02-2012)
Received 10,871 Likes
I come across errors in these on-line listings/catalogs quite often, especially for makes/models that are a bit off the beaten path....like Jaguar. Usually a couple of minutes Googling the part number will reveal discrepancies before you hit the "add to cart" button.
Sometimes it pays to do business over the phone with a real living person who specializes in Jags and already has figured out these details.
Just my crummy two cents :-)
trevc (11-02-2012)
Jaguar Classic Parts is usually my first stop to get the part number. Often I've seen parts vary by VIN and not just make / model / year.
In this case the diagram isn't very good, but the listing shows you want a JLM2128 not a JLM664.
Genuine Jaguar Parts and Jaguar Accessories for Classic Jaguars
Googling those part numbers will highlight the differences between them.
trevc (11-05-2012)
"Often I've seen parts vary by VIN and not just make / model / year"
Excelent point! A recent situation I faced; I have to change output shaft bearings in my car ('95 MY built 10/94). I called my parts man, Pete Bond at Coventry West, and asked for two "kits". "Ohhh, you have one of those mongrel cars. There isn't a kit for your car. I'm going to have to look your parts up because they're mix and match". It's worth paying extra for the knowledge and service. Just my $.02...
aholbro1
08-05-2021 05:02 AM
chatmanx
09-11-2015 07:17 PM
