Transmission light and engine stall '95 XJR
Hi All, After finally getting my XJR back on the road and enjoying daily use for a few weeks it has developed a new issue!
I was driving along the motorway at steady speed when there was a jerk from the drive train and the transmission light came on, but it didn't seem to downshift to third which I believe is the default for transmission limp mode. I was able to continue to work where I checked the trans fluid level, it was hard to tell because there were some bubbles in it, but I thought it might be low so I added a small amount. Drove home with no problem.
A few days later It turned over but didn't start. I charged the battery in case the voltage was dropping too much for the electrics during cranking, and it started. I did notice a whirring / whistle from the front of the engine that I hadn't noticed before, which died down as I let it warm up. Then it stalled, as if the ignition had been turned off. It started again but took a few seconds of cranking. I held it at about 2k rpm and it seemed to be running fine, then the transmission light came on and the engine cut out again as if the ignition had been switched off.
The transmission light was followed by the oil pressure light as the engine slowed to a stop, but the other warning lights didn't come on.
I have previously had a random stalling issue that was cured by cleaning the contacts on the ECU plugs, so may start there, but other than that not sure where to start, so any ideas appreciated..........
Regards,
John
Regards,
John
It's likely that the Transmission light is a red herring but you should get the codes read to be sure. The Trans light will come on if the engine stalls.
My primary suspects would be
1. Crankshaft Sensor
2. ECM Controlled relay
3. Poor earth or power connection between battery and engine bay (earth points and power +ve connections on bulkhead)
The following 6 users liked this post by b1mcp:
93SB (12-17-2020),
Don B (12-07-2020),
JohnXJR6 (12-07-2020),
Mkii250 (12-06-2020),
MountainMan (12-11-2020),
and 1 others liked this post.
I think Brendan is right about the transmission light likely being brought on by the stall, and the crankshaft position sensor would be an excellent place to start.
As an aside, I have a hazy recollection of advice against revving in neutral for any length of time as transmission damage can ensue.
The following 2 users liked this post by countyjag:
Don B (12-07-2020),
Thanks Guys,
I changed the crank position sensor a few years ago and it hasn't done that many miles since, but agree that the symptoms would match. I will try swapping the relay and see if it repeats. In terms of earth connections, do you think it is adequate to test for continuity, or is it a case of measuring a sufficiently low resistance between components individually rather than say between engine block and chassis? What could be considered reasonable/
Received 13,255 Likes
I don't think this will be your problem, but it would be worth checking your transmission fluid level again, since low fluid has been associated with stalling (though usually while slowing to turn or stop). To get an accurate reading, drive the car for 15-20 minutes at speed to bring the fluid to full operating temperature. Park on a level surface and set the hand brake. With the engine running and the brake pedal depressed, move the gear selector through each gear position, holding each one for at least 3 seconds. This fills the valve body and other passages in the transmission with fluid. Return the lever to Park. Now check the fluid, wiping the dipstick and reinsterting until you get a clean line of fluid on the stick. The level should be right at the MAX or HOT line. Adjust as necessary.
Regarding transmission fluid, the original specification was Dexron III. General Motors eventually discontinued Dexron III and stated that Dexron VI was backward compatible, but it is not suitable for use in your ZF 4HP24 transmission because its viscosity is too low. In the U.S., a commonly-available Dexron III equivalent is Valvoline Dex/Merc (in the blue bottle, not the synthetic version in the red bottle, which is too thin). In the U.K., another option is Mobil 1 ATF, which is a high-quality synthetic Dexron III equivalent of appropriate (high) viscosity.
We'll be anxious to learn what diagnostic trouble codes are stored - they may offer a clue as to your stalling, unless its the CKPS or its connection, which typically won't trigger any codes.
P.S. Sorry for the long post. It's late and I'm too tired to edit it for brevity.
Cheers,
Don
The following 4 users liked this post by Don B:
My memory may be as hazy as countyjag's, but I seem to recall that a Jaguar TSB warned against revving the engine past 2,000 rpm even with the transmission in Park, due to a risk of damaging the torque converter. If you have a different reference I would be grateful if you could post it so I can add it to my library.
Cheers,
Don
The following 3 users liked this post by Don B:
Hi xalty,
Cheers,
Don
Cheers,
Don
BMW NA service bulletin # 24 01 91 (3196) dated June 1991
https://e-wiesinger.de/tipps/AU-Anweisung.jpg
Don B (12-08-2020)
xalty,
Thank you for posting those. They seem to agree with the Jaguar TSB I'm thinking of. I can't read the German TSB, but here are the relevant warnings from the English TSB from BMW:
Cheers,
Don
Setup Procedure for I/M Emission Test
4. Restart engine, LEAVE TRANSMISSION IN PARK. After the engine is started, DO NOT move the gear shift selector through the Forward or Reverse gears before or during the test sequence. DO NOT EXCEED 2000 RPM.
Precondition Procedure
3. Engine may be preconditioned at a maximum of 2000 RPM for up to 90 seconds, at which time the repeat test must begin.
If the above steps are not followed, serious transmission damage can result.
Don
The following 2 users liked this post by xalty:
Cafcpete (12-10-2020),
SleekJag12 (12-17-2020)
93SB (02-18-2021)
Just to round off, it was the crank position sensor. On fitting an new on it fired on virtually the first turn of the engine and seems fine. From memory measuring the resistance, the old one was about 2.6 kOhms and the new one was about 1.6 kOhms, I might be wrong with the units, also the plug connector on the harness was damaged so I took the old sensor to an auto electrical factors called wood auto and they found a new Econoseal socket to fit for £4, so a job for this weekend. Hopefully reliability restored.
Don B (02-13-2021)
