Transmission Shift Override Screw
Need the steps to move the shift lever with the override screw on the shift gate plate
Car cranks the starter
4.0 normally aspirated with ZF4HP24
Looking for owner's manual in the meantime
I touched the battery terminals backwards in putting in battery backwards
Not in park switch makes as the key barral lock solenoid clicks and you can rotate the key to get starter rotation
Fully charged battery
Rhett
04-22-2014 07:16 PM
w1n9m4n
06-03-2012 08:26 PM
Boomer from Boston
02-06-2011 05:29 PM
