Transmission thumps!
![Exclamation](https://www.jaguarforums.com/forum/images/icons/icon4.gif)
Sometimes when i put my car into park, whether i am on a hill or not but its worse if i am on a hill, it doesnt seem to catch. the car will move forward or backwards depending on the road incline and the tranny makes loud thumping sounds. if i take it out of park and put it back in the problem goes away. what could this be? something i can fix at home?
Received 10,871 Likes
I'll as usual agree with Doug.
You could try 'thumping' park home but I doubt if this will do it.
One of my observations over the years, is that US owners of automatic vehicles, seem to rely on the gearbox setting the stationery aspect of the car, rather than the much more sensible approach of applying the brakes. Handbrake would be good.
This then leads to premature wear on expensive mechanical components, cf gearbox, rather than a couple of handbrake pads.
So if this happens to be the history of your car, give the gearbox a chance, like a manual car, put it in Neutral, and apply the Parking Brake.
A whole lot cheaper to sort out than a rebuilt gearbox.
Rhett (06-05-2016)
Right ! I always set the handbrake first then shift to "P"....on any car. Better to use the handbrake to hold the wieght of the car, not the parking pawl.
Plus.....if you're parked on a hill this prevents the hard-to-shift-out-of-park problem.
Plus.... doing so keeps the handbrake mechanism exercised and in good working order. Lack of use tends to allow the handbrake mechanism to seize up.
Rhett (06-05-2016)
Marka
22
09-11-2016 12:09 AM
