Tree dropped a branch, destroyed my driver's door.
Had a big front come through last night with a lot of wind. It knocked a branch off a tree which hit my Jag and took out the driver's window, the side view mirror and the door panel.
But no other damage, thankfully.
This will be an easy fix (compared to having it hit the roof or pillars!)
QUESTION:
Are 1995, 1996, 1997 XJ6 shortie driver's doors interchangable with VDP (long wheel base) driver's door?
Thanks!
PS: I call 'em 'shorties' because after drivng a VDP forever, they just look all scrunched-up and weird to me.
QUESTION:
Thanks!
Parker 7 (01-10-2024)
Save your driver door master window / seat controller as there are different versions
When reinstalling the connector back on ensure the pins lock bar is engaged or the pins can migrate away from connection
Someone had excellent instructions on door interior panel / card removal
There is a " clocking " procedure on the window motor / regulator and the motor can be run up and down with a battery charger ( high current arching hazard )
The final fine clocking involves holding the up button for a period of time telling the controller the window has arrived at the full up postion
captbob73
03-04-2023 10:07 AM
