trunk
does anybody have any idea why they would put the fuse box for the boot in the boot
not sure if my message sounded right before but I tried turning it with the key the boot won't open the fuse box to see if the fuse is blown is in the boot not helpful. the door is locked with the key and with the power but the truck whatever you want to call it well not open either way I need help from anybody would be great I don't want to replying one question
If the key lock is NEVER used, I have seen them seize from grit or debris so extra effort is required to get the mechanism moving again.
I have little sympathy for those that rely on the electric opening and then panic when the mechanical method becomes inop. (stuck)
As long as the black regular key is the correct one (not the VALET) it will eventually open the boot lid with lubrication and persistence.
I use the key every few weeks whether the car needs it or not!!
watto700 (08-04-2021)
SKRTSKRTXJR6 (08-10-2021)
Have you tried the basics? Spray some WD40 in the keyhole. Put the key in and out a few times. Jiggle it around a bit. Spray some more WD40 in the keyhole. Then leave it overnight. Try to open it with the key again in the morning.
Ive used this method multiple times. Use a flashlight through the bottom right hole of license plate holder towards the center. You’ll see the latch, use a long flathead screwdriver to push the latch over.
doodlebomber
23
11-17-2013 07:16 PM
CatoBT
03-21-2011 04:15 AM
