Turn siganl and headlight bulbs
This 95 Jag XJ6 has a cracked headlight and still works. I am afraid with wet weather comming it is going to burn out. From what I see you take the headlight chrome ring off and change the bulb is it that easy if not tell me how. Now my other problem is I have the drivers side turn signal bulb burned out and I don't see how that is changed. I read somewhere that I have to remove the front bumper. Any advice is appreciated. This is my first jag and I want to keep it but I want everything working.I hope I posted this in the right place.Thanks RickSku
The headlamp bulb is change from the rear. You will see a locking ring where the wires go in. Be fore warned, you probably won't pass your state inspection with the cracked lens.
The turnsignal is a pain in the @$$. It's much easier with a lift. You have to come from the backside. Removing the bumper is not necessary, but it may help if you snap your arm between the wrist and elbow.
