Turn Signal Reflectors
I dont imagine there is any huge difference in US spec but here in Europe (Ireland) the indicator units can indeed be easily popped out using a small putty knife or similar. Some have used a strong feeler gague, once it fits easily between the indicator / turn unit and the recess it sits into. Insert the blade into the upright end gap, nearest the centre of the car, not the outer side. This should push the plastic "tang" in, releasing it and the entire unit, with bulb, will swing out at that end, then just unhook it at the outer end, if that makes sense. Refitting is a reversal, inserting the outer side first until it engages, then snap the opposite end home. Easy to do once you're actually doing it!
Hope this helps and happy motoring.
Simprof (01-18-2011)
FS[SouthEast]: S1 XKE OTS Left Tail-light
SCMike
09-22-2015 07:34 PM
Richard_gib
09-12-2015 07:08 PM
