unbolting engine from tranny..
i am in the process of pulling a 95 xjr 4.o engine and am to the point where i have to separate the engine and transmission. i thought i read in the fsm that they have to come out together but cant double check due to a bad cd drive in my comp :/ very annoying as u just purchased the manual for this swap.. is there enough room to leave the tranny in the car and unbolt from the engine? and if so are there any new tricks to it? new to jags so any suggestions are helpful. thanks.
Dayn.
Dayn.
Lumppy47 is absolutely right about the top four bellhousing bolts. If removing the transmission from the engine, the combined unit has to be lowered at the rear of the transmission to even access them.
![unbolting engine from tranny..-05-gearbox-front-seal-flywheel-marked-torque-converter-realignment.jpg](https://www.jaguarforums.com/forum/attachments/xj-xj6-xjr6-x300-26/19022d1480966479t-unbolting-engine-tranny-05-gearbox-front-seal-flywheel-marked-torque-converter-realignment.jpg)
This shows the rear of the engine lowered by about 2 inches to clear the top bolts.
You can leave the engine in and remove the transmission but not the other way round.
As far as I recall, the selector assembly unbolted from the side of the transmission and there was no need to disassemble the centre console.
thank you so much for the sugestions they should help tons!! i was going to try to remove the engine mounts and lower the engine a bit and see if i could get it out with out removing the transmission, from your advice i take it thats not possible? thats confusing that the transmission can be removed with out the engine, but the engine cant be removed without the transmission. whats the reasoning behind that? thanks again.
Dayn
Dayn
Dayn
Dayn
You could remove the engine alone but I don't see how this is possible with the front crossmember in situ. Removing the Vee mounts would give a drop of maybe an inch. The oil sump is likely to contact the front crossmember at this point.
One of the issues with the X300 when trying to make some space is the way the oil sump wraps around the front crossmember. If you remove the crossmember, you can lower the engine unit:
![unbolting engine from tranny..-06-sump-replacement.jpg](https://www.jaguarforums.com/forum/attachments/xj-xj6-xjr6-x300-26/19026d1480966479t-unbolting-engine-tranny-06-sump-replacement.jpg)
With the engine lowered, you can access the top four bellhousing bolts.
Depends what facilities you have available for lifting / supporting.
Ok guys I'm understanding what you are talking about. My main concern is the space in the gurage that I am working with. I was planning on basically unbolting the engine ant tranny mounting bolts and using the engine hoist move the whole unit forward a few inches to get access to the remaining four bolts. Then supporting the tranny and leaving it in the car. I will try to make room in my gurage to remove them both as a whole unit. Does the front clip of the car have to be removed to do this? This is something else I am trying to avoid. Thanks.
Dayn.
Dayn.
Dayn.
Dayn.
As Lumppy47 commented earlier, getting engine / transmission reconnected is going to be a beast of a job. I'd be looking to lift the complete unit out in one if garage facilites allow.
mgb4tim is right about the relative positions of vehicle to ground. By raising one or even both ends of the vehicle, you can get greater clearance to rotate engine or engine and transmission past the crossmember and over the front of the vehicle.
If you need to put a temporary support for the tranny,a piece of 2X3 stud will bolt through the jacking supports,(helps keep the unit flat when re installing).Also you may be able to leave thr radiator in,just cut a piece of 1/2 in plywood to the size so that there wont be any damage.You can leave the front clip on just remove the bonnet.
Well I got the engine Amy tranny out as one unit last night went easy and painless. After starting I realized I would have enough room to take them out as one unit. I ended up having the front of the car on ramps and lifted and angled the unit out. Was way smoother than I expected. Thanks again for all the help and suggestions really helped alot. Now getting it back in and remembering where all the hoses and wires go..
OkieTim
09-08-2015 04:48 PM
1995, car, crossmember, engine, hurt, jaguar, pull, removal, remove, replacement, rr, supporting, taking, transmission, x300, xjr
