Under radiator cradle rubbers
Old 08-27-2016, 03:33 AM
Nibbster's Avatar
Default Under radiator cradle rubbers
I know I've lost at least the one on the driver side but suspect both may be gone - will check later
Can't seem to find part number for these so what has anyone else used?
These are the rectangular pads on the cradle facing towards the road - must replace the other round bushings as well as although replaced a couple of years ago the last time I looked didn't look too healthy.
Considering ice hockey pucks as a last gasp solution
thanks
c
Old 08-27-2016, 06:06 AM
RJ237's Avatar
Received 2,819 Likes on 2,246 Posts
I got mine from Rockauto, URO APA MNA4241AB.
Don B (09-01-2016)
Old 08-28-2016, 04:15 AM
Nibbster's Avatar
Those are the round mounts - there's meant to be 'pads' underneath the cradle and those are the ones I can't find
But thanks nevertheless
c
Old 08-28-2016, 05:42 AM
RJ237's Avatar
I don't recall those, have to look at the diagram. I'm rather certain I replaced all the rubber.
Old 08-28-2016, 09:01 AM
aholbro1's Avatar
Received 1,643 Likes on 1,068 Posts
I'm lost as a ball in high grass, too. Maybe a picture?
Old 08-28-2016, 07:40 PM
1997Sovereign's Avatar
Mine were also round,with pegs in the bottom of the radiator that pops into the center.
Old 08-29-2016, 03:03 AM
rads's Avatar
Default pad, lower CCC003853
If my car ever had one it is missing now!
Old 08-29-2016, 06:01 AM
RJ237's Avatar
That's what I recall. I see I bought four of them, and I don't think there are four on top.
Old 08-29-2016, 06:26 AM
Maraud's Avatar
The A/C condenser also eats bushings over time, while you are at it maybe wise to check that too.
The following 2 users liked this post by Maraud:
Don B (09-01-2016), RJ237 (08-29-2016)
Old 08-30-2016, 07:08 PM
Two on top and two on the bottom,had to use dish soap to lube the top ones because they squeeze into the bracket.
They are cheap enough to do like suggested and swap the a/c ones at the same time,like I did not do and now need to do the job twice.At least it is a somewhat easy one.
Old 09-01-2016, 10:21 PM
Received 13,255 Likes on 6,562 Posts
Hi Nibbster,
I think you must be describing the radiator mounting "Pad", which is Part 6 in the diagram below, from the section of the catalog titled Body Metal Panels and Sealing/Fixed Body Panels/Radiator Mounting Panel:
The part number is CCC3853 but jaguarclassicparts.com lists them as NLA.
I think most owners haven't bothered to attempt to replace those, either because we haven't noticed them or they have deteriorated and disappeared. The parts RJ237 and most of us have replaced, the "cooling module mounting bushes," part number MNA4241AB, look like this (alongside the remains of an original one):
And here they are installed:
As far as those pads go, if you think they are necessary I assume any suitable foam rubber could be cut to fit. Maybe something from the weatherstrip and insulation department of your local home improvement store?
Cheers,
Don
The following 3 users liked this post by Don B:
aholbro1 (09-02-2016), littlelic69 (09-08-2016), OzzieJagMan (07-11-2020)
bigdhenderson
12-12-2016 10:52 AM
EZDriver
04-12-2016 06:30 PM
silversurfer1221
04-06-2016 05:26 PM
JagSTR2004
03-31-2016 08:22 AM
10-04-2006 12:42 AM
Quick Reply: Under radiator cradle rubbers
