Update on Throttle position sensor
![Smile](https://www.jaguarforums.com/forum/images/icons/icon7.gif)
I'm sure some of you are waiting to hear the results of my search for a less expensive TPS for the 4.0L X300. I thought the unit from the Ford Scorpio was my best bet. But with the help from Mark and a new Ford Scorpio unit in hand I lost that bet. The Scorpio unit does not rotate in the same direction.
But I am still not giving up and I am open to any other suggestions.
One thing I have tried on my car has helped and I would suggest for anyone having a stalling problem to try it. I use my car as a daily driver and do not have a frequent stalling problem. But I do want to have a good solution when it becomes frequent. What I do is every few days I go in and rotate the butterfly valve on the throttle body a bunch of times without the engine running. I think this may clean the contacts in the TPS somewhat. Since I have been doing that I have not had a stall. But that has only been for a short time.
I'll keep everyone informed as to any progress and I look forward to hearing from anyone on this subject.
Thanks for listening
I have added a link to this thread at the end of the last one on this subject (https://www.jaguarforums.com/forum/x...-sensor-89513/). Otherwise it will be very hard to follow and find a solution, years from now.
Once I found the rotation different I didn't go any further other that external observation. The mounting for the spinal is not the same. Looks like the spinal on the Scorpio is a half round spinal. And the mounting hole does not go all the way through. It would be quite a job to mount it unside down with a major modification to the spinal hole. If I don't come up with something else I might look at that.
Aus V8S
11-13-2015 11:01 AM
KarimPA
09-12-2015 08:15 AM
