upper fan shroud clips source?
The following 3 users liked this post by SleekJag12:
Received 13,310 Likes
Hi Oliver,
Do I remember correctly that this is a U-shaped spring clip that slips over the upper edge of the fan shroud and maybe the radiator to hold them together? if so, see if the U-clips at the link below are similar, or just google U-clip images.
Walmart U-Clips
Another potential source is at the link below, but you may have to search through dozens of pages:
Auto Body Clips
This came up when I searched U-clip, you'd just need to buy a box of 100:
Auveco #9417 U-Clip
If you have a good Ace or True Value hardware store nearby, you may find what you need in their specialty hardware section. There might also be something suitable in the specialty body parts section of your local auto parts store.
I assume Richard is thnking of binder clips? A small binder clip could definitely work, but a U-clip would fit more securely with its narrower throat.
Cheers,
Don
Walmart U-Clips
Auto Body Clips
Auveco #9417 U-Clip
Cheers,
Don
The following 2 users liked this post by Don B:
93SB (09-10-2022),
MountainMan (09-10-2022)
G'day Oliver,
I just googled the part number and it appears that at least a couple of suppliers have them in stock.
This link is to a supplier in Melbourne, Australia https://www.ebay.com.au/p/21018080139
And this one to Terry's Jaguar Parts https://www.terrysjag.com/product/CBC1707.html
Cheers,
Jeff.
Cheers,
Jeff.
944play (09-08-2022)
G'day Oliver,
Yeah the shipping costs of small items, at times, is prohibitive but sometimes you just have to have it.
The shroud supports you want are available at Jaguar Classic Spares but again the shipping is around 20 times the cost of the item. Off to the wrecker you go then.
Apparently there are only around 15 or 20 V12 X305 cars in Australia so the chance of finding anything at a wreckers here is pretty remote.
Cheers,
Jeff
Cheers,
Jeff
944play (09-10-2022)
