Using Gasohol in X300/XJR
I am just about to buy a 1996 XJR, all being well! My problem is the scarceness of 95 octane petrol here in Thailand. Does anyone know for sure whether the XJR will safely run on Gasohol 95 (90% 95 octane petrol with 10% ethanol)?
Alternatively, I might have to consider an X300 (normally aspirated, 4.0 litre), can that be run safely on gasohol?
I have tried a search but no results, does anyone know?
Thanks.
Thanks.
Received 10,880 Likes
Bill999 (05-06-2013)
Don't know what rating system is used here all I know is I have a choice of Shell 95 petrol very occasionally if I'm lucky, 91 petrol, 91 gasohol or 95 gasohol. Whatever the rating system I'll have to use Shell 95 or gasohol 95.
You Thai gasoholics could consider mixing small amount of T-WC3 outboard engine oil in your petrol as discussed at length in this X300 forum somewhere.
The theory is the oil stops the ethanol drying out fuel pumps, rubber diaphragms in the fuel system etc.
I do it in NZ even though there is no ethanol in my fuel. I am lucky - I can buy 98 RON petrol which I think is shipped from Singapoer refineries.
I add about 2 mL outboard oil per litre petrol, ie about 120 mL for a 60 litre petrol fill-up
Received 2,263 Likes
Thanks, Doug, that's what I needed to know.
AFAIK, all Jaguars built from around 1990 onwards can use E10.
Is this serious, putting engine oil in the petrol? Doesn't that mess up the running of the engine?
Some owners are using the outboard oil in extremely diluted ratios of ~500:1 as an experiment to see if it helps.
Besides, the oil is a very pretty blue colour
Just did 5 thousand k round trip in my XJR using 98 octane and 120 ml TC-W3 per tank
First time I have ever gotten more that 500 out of a tank one section nearly got 650 k,s to a tank and runs so sweet
came back home totally refreshed might do it again in a month she just purrs on the open road mostly cruise control took her up to 180k,s couple times overtaking a few cars at a time
I did notice after the first tank the back of the car had a blue film on it valve stem seals I think
but after the trip clean and running very sweetly and 120ML is nothing I was using 140ML went back to 120ml
XJRengineer
XJ40 ( XJ81 )
06-26-2013 07:15 PM
