Using oil
Received 13,205 Likes
Hi Godspeed,
For comparison, modern engines with low-friction piston rings can use as much as one quart of oil every 1,000 miles or so. The owner's manual of a Mercedes E550 I service states that, depending on driving conditions, the engine can use a quart of oil every 640 miles. So by modern standards your oil consumption is not excessive.
If you feel your oil consumption has increased, the first question that comes to mind is whether you are using the correct oil viscosity. I am attaching a TSB with Jaguar's revised oil recommendations. For most temperate climates, summer oil viscosity should be at least 10W-30 and ideally 10W-40 or heavier. Use of lower-viscosity oil can promote increased consumption.
Another possibility is that your crankcase breathing system is obstructed, causing positive crankcase pressures and oil being forced past the piston rings. The crankcase breathing system is designed to maintain a slightly negative pressure in the crankcase to reduce windage and other issues, but if the system becomes obstructed, combustion blow-by gasses can cause high positive pressures in the crankcase.
Cheers,
Don
Cheers,
Don
The following 2 users liked this post by Don B:
93SB (06-02-2019),
MountainMan (06-02-2019)
Hello Godspeed, Have you cleaned your throttle body lately? There is a hose that connects from the cam cover to the bellows before the throttle body. In the fitting on the bellows is a brass dish that causes the depression that
Don B the moderator is speaking of. If it is missing after a throttle body service, Up goes your oil consumption. Also, Changing your oil sooner rather then later can reduce your oil consumption.
Larry Louton
Larry Louton
Don B (05-30-2019)
For the benefit of other readers who may find your thread and go looking for their PCV system or valve, Jaguar does not use the term Positive Crankcase Ventilation, nor does the AJ16 engine have a PCV valve. Jaguar uses terms like "Engine Breathing System" or "Crankcase Breather System" in the parts diagrams and Workshop Manual.
Please let us know if the cleaning seems to have made a noticeable difference.
Cheers,
Don
The following 3 users liked this post by Don B:
The following 5 users liked this post by motorcarman:
93SB (06-02-2019),
aholbro1 (06-02-2019),
Don B (06-01-2019),
hjsteadman (06-11-2019),
20W-50 was Jaguar's recommended viscosity for the AJ6 engines in most climates, and it makes complete sense for use in the AJ16 in Bob's home state of Texas. As I mentioned earlier, I'm an advocate of using the heaviest viscosity recommended by Jaguar for your climate.
93SB (06-02-2019),
Don B (06-03-2019)
orangeblossom
02-28-2016 04:35 PM
