Valve Cover Gasket leaking again....
Old 02-04-2016, 08:36 AM
hak's Avatar
hak
hak is offline
Originally Posted by caldercay
**never** use any sort of "stop leak"
they only very temporarily hinder something that **needs** to be addressed
If you check Amazon customer reviews for this product you will find that many people have had permanent success at stopping oil leaks with this product.
Old 02-04-2016, 10:59 AM
Old 02-11-2016, 07:00 AM
JohnXJR6's Avatar
My valve cover is also leaking on my '95 XJR. I replaced the outer seal and plug well seals a few years ago now, but I did not replace the seals around the bolts. This may have been a mistake as the old bolt seals may have compressed reducing the clamping force on the seals due to the shouldered bolts mentioned above. At the time I cleaned out the oil separator plate / mesh in the cam cover with petrol before refitting. I probably need to look at my hose too.
bamforp
09-26-2021 08:04 AM
aholbro1
08-05-2021 05:02 AM
dsnyder586
04-04-2019 02:38 PM
hoodun
09-07-2015 07:02 PM
philwarner
09-06-2015 11:10 PM
Quick Reply: Valve Cover Gasket leaking again....
