Valve cover gasket replacement
HI folks.
I have a 1997 jaguar xj6l in Kansas with what I believe is a bad valve cover gasket. Visible oil leak around entire cover, badly caked and burned at the very front.
I have found the part online (nbc2525aa) for around 30-50 bucks. I was wondering if anyone knew where to find the 13 o ring gaskets for the bolts and what other items (spark plug gaskets, specific tube of sealant?) I will need to tackle this job. I have read some vague guides for this project but Can't seem to find one for this year and model.
Thanks in advance, these forums have helped with lots of other projects but first post here.
Don B (01-19-2017)
I've moved your question from General Tech Help to X300 forum. This is the place to post technical questions about your model.
Welcome to the forum, Tanner. This one has links to everything you might want to know about it:
https://www.jaguarforums.com/forum/x...thread-163891/
Don B (01-19-2017)
