Valve cover inside shield ?
The following 3 users liked this post by Ric in RVA:
Lady Penelope (02-16-2018)
Thanks Aholbro1 , I will have to read your work later . Link below :
https://www.jaguarforums.com/forum/x...thread-163891/
I would like to see if a quality separator catch can would replace it too. My powder coating guy would not do the VC since he would have to remove or risk getting blast media in it which would be BAD.
Most of the cheap ebay ones are just cans and I would want a real separator with baffles.
I've installed a catch can in my car. Catches tons of water in the winter time, and some oil in the summer months.
I am planning on replacing the gaskets on the camcover soon and am considering either soaking the camcover breather area with degreaser or just removing it altogether. I can't imagine it doesn't get caked up with grease based on what I've caught with my oil catch can. (I shoved in a stainless steel mesh scrubber inside the catch can to force the gas to condensate. It was pretty nasty with about 1 years worth of service)
https://www.jaguarforums.com/forum/x...engine-160018/
I'm somewhat surprised that the powder coating company didn't have a way to deal with the baffle such as just masking it off when they sprayed the powder.
Regarding a catch can, the following is what I have fitted. As noted above, it catches a LOT of water, which is mixed with oil too. I usually check it every couple/three weeks. I let it go for a couple or so months one time and it was practically full.
https://www.jaguarforums.com/forum/x...7/#post1708029
They said they could plug it and tape it before media blasting but could not guarantee it and that media would be bad for engine. We discussed and I decided not worth the risk.
Not all blast media has to be some oxide, sand or glass.
For example, I've seen dry ice blasting which would obviously melt, and even media like walnut shells that I would think one could burn out and might not even really faze the engine if a few bits got ingested (not sure on that one, but maybe)?
And of course another option is chemical stripping.
...and if one has the catch can, I wonder if the baffle is really all that necessary anymore.
If you can get some bathtub caulk to stick and mask off the inlets and outlets and let them know it would be your responsibility to ensure that it's removed shifts responsibility away from the shop . I found a scientific paper on " clear " powder coating magnesium a few months ago as it is used in areostructures and has special problems for a clear outcome unlike other metals .
Ric, find a new powder coater. It needn't be blasted. They need only run it through the "standard powder coater's stripper" bath....twice, probably, but that is all that's needed. And even if they blast it, more oil and stuff will come to the surface when it is heated so it'll still need an additional process, either re-blast or another trip through the bath. The magnesium alloy is more porous than not.
Can't find the paper but I did find this on the internet below :
The key being an alkaline cleaner and heated off gassing for a clear and not yellowed result .
Walnut or baking soda blast ?
I haven't done mine . Still in work for something wonderful as a elegant solution .
We had an honest conversation about that filter and the gunk that would get caught up in the mesh inside it during the stripper, as well as the issue of not getting any media out if it got in there and the inability to reattach said cover and I decided it wasn't worth it.
I think any powder coater that thinks they can pull it off without that discussion needs to be skipped.
I have some high temp silver that will be fine. But may go crinkle black...
The following 2 users liked this post by michaelmedina2005:
al_roethlisberger (02-27-2018),
Lady Penelope (02-26-2018)
Working on plaster molding the plastic surrounds after filling the dimples with some body filler to overlay some real carbon fiber with actual resin . Will be covering the coil and fuel rail cover and gold leaf ( or fools gold also available ) with red paint on the unleafed lettering as I reengineer the engine out to what it could be . The valve cover is still a secret ( don't tell any one ) under developmental with Dupont . You gave me the idea earlier with what you did with yours . Thanks .
Why ? Because she's special , just ask her . I catch her saying it all the time .
David Bedoya
01-15-2017 04:12 PM
TopHatChef
04-28-2015 01:29 PM
bootleg
07-03-2008 02:45 PM
