Valve seat contact width
Hi everyone!
I'm currently working on a cylinder head of an AJ16 XJR. My exhaust valves are quite pitted and kind of burned so I'm having an experienced friend helping me re-grinding them and the valve seats. I have the AJ16 manual pdf and I've been searching for all measurements and angles needed, but I can't find anything about the contact width of the valve seat.
Does anyone know this?
And I don't see any specs unique for the supercharged version, aren't the inlet valves bigger on those engines? And is the valve lift the same on N/A and SC?
In very grateful for any kind of help here!
Yes I've seen that, but it only shows a picture of how high the valve should be seated, in my mind a kind of strange thing to emphasize... It doesn't really help I'm afraid. Thanks anyway!
Parker 7 (02-02-2022)
The number on the cam is a blank part # before machining down
So it might be hard to nail down which cam is installed unless TSB 03.1 - 05 has been performed and notated properly
Something I picked up from reading without knowing for fact
http://jagrepair.com/images/TSB/X300...%20Changes.pdf
![Icon Dance Disco](https://www.jaguarforums.com/forum/images/smilies/icon_dance-disco.gif)
So I'm assuming that even if the cams have different profiles, the clearence is the same because the manual only show one spec.
Or is there a specific manual for the supercharged version? I haven't found one at least!
I really hope that someone who's done a valve Job on these can share some experience here. Otherwise I have to look at some other similar engine for the specs...
The following 2 users liked this post by Larry Louton:
Parker 7 (02-05-2022),
Peter Pennström (02-07-2022)
