Which version of IDS and Mongoose works with X300?
I have IDS 130 and mongoose knock off. Overall the IDS seems to work, except I get an error for all modules when I try to pull the codes:
[ERR 0x22] "The request can not be processed due to a bad specification or missing parameters".
Is there a version of IDS that is known to work with Mongoose for X300 cars?
If there is a VCM + IDS combination known to work, I would be interested in that too,
The following 3 users liked this post by b1mcp:
I guess you've seen this?
![](https://dl.dropboxusercontent.com/u/11575086/Mongoose%20Compatibility.gif)
Mongoose should be OK, I also suspect it's the software installation that might be the issue...
I recall also seeing ERR 0x22 when running my setup in Legacy IDS a couple of times. It's fine when running SDD on modern vehicles, but in Legacy IDS it's "buggy" will freeze or crash from time to time.
If I had one of the older cars I would be looking for a WDS or a PDU system, while the Mongoose is cheap, it doesn't seem to be reliable in Legacy IDS...
MountainMan (09-11-2014)
philwarner
09-05-2015 10:05 AM
Chet Ramnarain (bozzner)
09-03-2015 12:21 PM
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
