Voltage dial goes to nothing
SO today after a crappy day of golf I started up my car and backed up then all the sudden the Battery light came on and the dial went to 9(might have been that way just noticed it after the light came on). Then a few minutes later the Engine, I think top left light, came on and I kept going then the ABS and the traction control came on then about 10 minutes later the airbag warning displayed. I was able to drive home which was about 15 miles. However, when I had to stop and then go the vehicle had no acceleration. When I got home the car would not start again
So I looked in the manual and of course and it said when the battery light comes on it is the alternator. So off I went to take it out, which was not fun, took it to the auto store to get it check out and it was fine. Battery is a year old so that can't be it.
So the only thing that it could be is the ECM? What was interesting was that my diagnostic tool could not speak to the ECO BUT I am not sure if that was just because the power was so low.
So looking for some input on what to check next. I still have a spares car and I assume that the ECU is OK so if I need to do that I will but don't want to until everyone chimes in.
Help Please
Here is the latest. I charged the battery, started the car drove around and the car is not charging even though the Alternator is good. I was able to the the OBD2 talking to the care but is showed no errors.
Help Please
Today's batteries are junk , have them test it
There is a alternator regulator excitation fuse # 10 / 5 amp RH engine fuse box and some items wired into the same fuse that can cause that excitation to the alternator problems .
You can check the battery's connections
The following 2 users liked this post by Lady Penelope:
al_roethlisberger (05-16-2018),
Don B (04-21-2018)
OK , unplug the sounder unit on the lower shelf just fwd and outboard of the wiper fluid cap . It's a big black square thing with 2 wires . And remove the 2 or 1 washer pump relays ( R7 and R8 ) . And the A/C clutch relay ( L3 ). Pull apart and clean the 2 square connectors with about 10 wires each below the wiper fluid fill cap , the most important is the White / Blue wire in position 2 on the black connector and a second wire White / Blue in position 4
Don B (04-21-2018)
Received 13,402 Likes
Many engine regulation wires go through the connectors including the fuel pump turn on circuit so you would have to look and judge it's condition and reconnect . l do have a source for a new connector(s) if needed .
Don B (04-21-2018)
going to take some sandpaper to the connector as they look clean but seem to be a little oxidized. so when i get them clean and put back together and fusses pulled and ac removed do I then go ahead and try again. by the way post 4 looks the same unless i am missing it. sorry to be such a pain.
