water pump
Fairly easy, but the bolts can be a little hard to reach. I found it easier to take the air pump off, then back off the tensioner for the alternator. Remember where it was so you can get the proper tension again, unless you replace the belt.
If you check on ebay you can buy a workshop manual CD. It has a parts section and repair including torque settings. Originally from Jaguar Heritage.
Ozzy_UK
45
02-19-2019 02:05 PM
FS[SouthWest]: Red 2001 XK8 Convertible in Colorado
picard
10-12-2015 11:56 AM
