Water pump on the way out...
Old 01-30-2013, 08:13 AM
Ziggy's Avatar
Originally Posted by Doug
One of these would help....only $7 or so in most parts stores in the USA.
KD Tools KDS835 Mechanics Stethoscope, Listening Tools - Toolfetch.com
Did you start the engine when you had the belt off? If the noise disappeared then you'd know for a fact that it was one of the belt driven devices.
It's not absolutely carved in granite that a noisy bearing will be a loose bearing. Sure would be nice if it was, though :-)
Might try unplugging the alternator. If the noise diminishes or disappears with no electrical load, there ya go!
That looks like a rather useful thing to have around! When I took the belt off, it wasn't making the noise all of the time - it's got worse over the last couple of days, so I guess it'll have to come off again for another check...
I doubt it's the alternator - as above, that's smoother than the WP, and one of the first things I looked at was whether turning on all the lights, radio, heater etc made any difference!
Old 01-30-2013, 04:44 PM
Ziggy's Avatar
Latest theory: The top hose was leaking from the joint on the thermostat housing, coinciding with the start of the funny noises. I've replaced the hose, but what if the leak was running down the water pump, and made it into the bearing? It could quite conceivably have dried it out, but not (yet) caused it to wear out - the opposite of what usually happens! Sounds tenuous, but why would the bearing be sealed particularly well from the outside?
Old 02-18-2013, 02:51 AM
Ziggy's Avatar
Just for anyone searching for the answer to the same problem - the above is indeed the noise a water pump can make. No play, no leaks, but even when spun by hand once removed, you could hear that it wasn't right!
Old 05-21-2013, 09:37 PM
Super's Avatar
Default Water pump noise
I'm changing my pump for the same reason. Noise similar to yours and no leaks whatsoever. I thought it was my supercharger, once the belts were off it was obvious that the pump was toast.
Dave 97 xjr
Wahooesprit
12-23-2019 02:01 PM
Ozzy_UK
45
02-19-2019 02:05 PM
Ozzy_UK
General Tech Help
01-14-2016 02:52 PM
ksjaguar
11-03-2015 10:14 AM
picard
10-12-2015 11:56 AM
Quick Reply: Water pump on the way out...
