water temperature gauge acting funny
Hello, I have also discovered my water temperature gauge takes a very long time for it to get near the warm side and some times it hangs out around the 1/4 area. I replaced my thermostat when I did my water pump. Could it be the sensor going bad or the gauge on the cluster? No codes active on the car.
Ericbilt25 (02-24-2014)
I forgot I just went to the Jaguar dealer and asked for the original thermostat. I guess I'll be looking for a new sensor soon. Is there a resistance chart according to temperature of the water?
Hi
I had this problem and popped out the Thermostat and discovered it was distorted and jammed ...... I popped in a new thermostat 192 F and corrected the problem. The Temp Gauge works fine now. I have noted reading here that the temp sender might be faulty ... perhaps but check the thermostat first..
BigBoss in Dallas TX
![Icon Toast](https://www.jaguarforums.com/forum/images/smilies/icon_toast.gif)
BigBossRadio (03-10-2014)
NTL1991
XJ40 ( XJ81 )
09-20-2015 06:22 PM
chatmanx
09-11-2015 07:17 PM
