Weird buzzing noise from driver side ac vent
I am going to go for a bit of leaf or debris ingested into the fan and touching the blades as they rotate.
I had been wondering about the climate control system aspirator, which is a tiny fan which draws air over a thermocouple to determine the cabin temperature, but it looks as if your car is LHD, and I think it is always located in the RHS knee area. It has a plastic cover about an inch square, and is worth checking anyway, as the thermocouple will likely be covered in dust and would benefit from a clean
944play (10-30-2020)
