Were NAS XJ12's Fitted with LSDs?
Hello,
I need to replace a leaky pinion seal in my 1996 XJ12, and I was wondering if US-Spec XJ12's were fitted with Limited Slip Differentials. That will let me know if I need to make any special considerations as far as gear oil and additives as I want to make sure the diff is topped up before I can get the work done.
I wasn't sure if LSDs were omitted if the car has traction control fitted.
Thanks,
Nick
Thanks,
Nick
I think that all XJ12 and XJR sedans up to 1997 were fitted with limited slip diffs.
There should be a tag with red/yellow stripes and a BLACK line or X through it.
The red/yellow is the ratio and black line is LIMITED SLIP.
It is on the diff but might be worn or fell off.
It also might be covered with grease or dirt.
bob gauff
bob gauff
Received 10,906 Likes
How about model year 1997?
While traction control is not an option on your sheets for the regular XJ6 4.0 in 95 and 96, it most certainly was for 1997 as mine has it.
The LSD possibility will be checked next week per Plums and Motorcarman suggestions on how to identify when I get the 60k mile service done.
aholbro1
08-05-2021 05:02 AM
xjrjag
09-27-2015 01:53 AM
philwarner
09-05-2015 10:05 AM
