What is this?
What is this?
Just doing some odds and ends today, when I noticed something on the air filter housing box. Underneath the box itself, is a plastic pipe, about 1" diameter and about 2" long, There is a yellow plastic blank fitted over the end of it, with nothing else attached. The pipe faces back towards the windscreen. Just wondered what it is, what it's for?
Thanks.
Thanks.
That leads to the air injection pump (left-side arrow)
It's hard to say from that picture, but thanks for the reply. The pipe I'm talking about is very clearly visible from the drivers side wing/fender, (RHD) looking straight across the engine bay. Maybe a picture would have helped! I'll take one tomorrow and post it if needed.
As mentioned, there is nothing connected to this pipe, just a blank cap.
Thanks again.
Thanks again.
Thanks again.
Thanks again.
So, given my limited knowledge of the science involved in air intake physics, would it be of any value to put another air intake onto this "spare" pipe? Maybe a tube /hose arrangement with an aftermarket K&N air filter set up attached.
How would extra air affect performance and fuel consumption, if at all? Or would it be of any value to vent warm, recycled air into the system via this pipe? Or what about pumping it in, via a controlled electric pump, which is what I assume the American spec cars do?
Just wondering................
Well that air box I photographed is from an ex-Sinapore car so I guess that means in that market they are the same as UK then
