What is this leak?
What is this leak?
I finished the cam cover gaskets. Got everything put back together. New spark plugs and new coil packs. Alternator rebuilt. Started it. Running very good. Volts are where they should be. I was looking for leaks. I found one. Not from the cam cover. It's just above the engine number. I made a video. Sorry for the fan noise. Any ideas? Can I smear some RTV on it to stop it?
https://youtu.be/aBUH0De142w
That is the VERY COMMON head gasket leak from the exhaust cam oil feed gallery.
The leak has been a plague since the AJ6 engine introduction.
Jaguar issued several SUPERSEDED head gaskets for the AJ6/AJ16 engines.
The intake cam oil gallery has a locating ring/hollow dowel around it so it is not as susceptible to leakage.
The only way I know to stop the leak (for a while) is to replace the head gasket.
bob
bob
The following 3 users liked this post by motorcarman:
Don B (01-26-2020)
Unfortunately I have this same leak. I attempted to apply high temp gasket maker and also exhaust putty. Both of which have failed, but managed to reduce the amount that seeps out.I doubt this will be an issue as long as you top off your oil. But I'm going to attempt to reapply but be sure to thoroughly clean the area so the putty or gasket maker adheres well to the surface.
edit: I apply it on the outside of course, at this time I do not have the means to have a new head gasket installed
1997 Jaguar x300 4.0 NA
cadfael_tex
07-05-2011 07:46 PM
