What is this piece under the hood
Might try to glue back together with JB - Weld
Comes in yellow and red version with short 5 min or 4 hour set time before longer cure time
4 hour set time recommended
If you take the top of the actuator apart for more cable access it is a can of worms to be avoided
If you look at the very bottom of the actuator cylinder there are 2 wires that can have the insulation deteriorated and breaking off
On the later model years of the X300 there is an adjustment to the cables to the actuator that effects idle from reading others , I wouldn't touch that yet ( adjustment ) if an idle issue
The actuator is between the cable run from the foot pedal to the throttle butterfly
Idle is a common issue with the supercharged version
AZDoug
02-05-2024 04:26 PM
AZDoug
09-14-2023 03:25 PM
