What is, or is there a testing procedure
Received 10,881 Likes
The trunk-lock actuator should test between 20-30ohms. Mine tested at 4.65ohms so it's going to have to be replaced. If anybody has one let me know. I also remover the trunk-ajar sensor which was remaining on when running.Sensor removed and the alert light is out. Although the sensor is functioning properly there appeared to be a missing spacer (like a nipple that filled the 1/8" gap between the lock trigger and switch. This also turned out to be the reason for the malfunctioning central locking system. With the malfunctioning trunk-ajar sensor removed the remote locking system is now fully functional.
Hope this helps somebody.
Cadillac (11-15-2011)
Received 2,192 Likes
with one that tested at 22ohms. Trunk now unlocks from the remote and interior switch. The little buttom thingy on the trunk isn't functioning but i'm pretty much satisfied since i'm no longer worried about locking the keys in the trunk.
Thanks guys for your suggestions
My wife hates the PANIC alarm, now i can't stop playing with it.
