What type of bulbs do I need?
I pulled the non functioning radio from my donor car and have it apart cleaning all the switches and buttons with electrical contact cleaner. I also resoldered a couple of connections. Before I try it out I thought I would also replace the light bulb for the shifter,the one that lights up the whole strip. Does anyone know the type of bulb I need?
I also could use the bulb type that is used in the sport switch for the transmission. Thanks.
T5/T10 style with # 74 miniature wedge bulb , same ones used in the other areas ? Without seeing the shifter and N/S specific ones myself the below links may help : 5 mm approx 3/16 ", 18 mm approx 11/16 "
74 24 Instrument Panel Gauge Colored Led Bulbs Lights and Lamps)
LED Bulb Cross Reference Chart and Compatibility Guide | Onyx Performance Lights
https://www.jaguarforums.com/forum/x...dimming-38712/
https://www.jaguarforums.com/forum/x...ination-88250/
The following 2 users liked this post by Lady Penelope:
Scotlad (10-27-2017),
VickTrader (01-14-2024)
