What would you do - idler pulley bolt snaps
Untensioning the belt I was able to remove the pulley and tensioner. My local dealer ordered the block and bolt for me and it will be here tomorrow. I took some pics and will post it in case it ever helps someone else. Although the other belt looks ok, I'm going to replace it since I'm already in their.
Just need to figure out how to reduce the tension off the belt.
When you state, "... how to reduce the tension off the belt", what are you really stating? That you don't want as much tension as should be? Or are you still having an issue loosening a bolt to reduce the tension to remove a belt?
PB Blaster (way better than WD40) is the best stuff I've found to spray potentially stubborn bolts, and nuts, and so on, before removing them.
Regarding my statement about reducing the tension off the belt; I'm referring to the other belt that runs around the alternator. I already loosened the nuts on the tensioner, both top and bottom and I still don't have enough slack to remove the belt?!? There must be a trick to this...
Received 10,867 Likes
Well if it the same system as my 92, then loosen the alternator pivot bolt a little so that the alternator can actually move. Or if it is the AC belt, then you will need to loosen the compressor pivot bolt. (for the AC you will be under the car)
Agreed, replace both belts at the same time, peace of mind, and only do the job once.
Replace your belts and bits.
Set your tension correctly.
When setting the tension, After slacking off the 2 nuts as you have done, I tend to use a short tyre lever to manually pull the alternator/pump and get it into position with approx tension before spinning up the tension nut to finish.
And then lock down the pivot bolt to stop the alternator/pump moving. (keep a spanner on the tension nut whilst you are doing this so that you can adjust, in case the alternator/pump moves when you tighten the bolt.
Finally tighten the lock nut.
Check your tension is still good. (if not, then repeat, you'll get the hang of it).
If you don't loosen the bolt, then all you will do when winding on the tensioner is risk breaking it.
The alternator/pump needs to be free to move for you to tension the belt. (pretty much the same on any vehicle belt driven application, the alternator, PS pump, AC, whatever, needs to be able to pivot for you to be able to tension or remove a belt).
