Wheel Sensors
Old 02-22-2018, 02:20 PM
EZDriver's Avatar
Smile Wheel Sensors
Have a question regarding wheel sensors on a 1997 X300. A friend has a 97 X300 and his check engine light is ON all the time. He took it to a local mechanic, who I highly respect, and was told the Ck Lt being on is due to the wheel sensors not functioning properly. I just want to know if this analysis is correct. And if it is what is involved in servicing the wheel sensors. My 95 has never had a problem with wheel sensors that I know of for the 14 years that I have owned it.
Thanks guys for the help
Old 02-22-2018, 02:46 PM
Ric in RVA's Avatar
Cleaning them is first step. Brake clean and a rag.
Front will come out. Rears probably wont but you can reach into rear upright.
Clean plugs and check wires too.
Lady Penelope (02-22-2018)
Old 02-22-2018, 04:15 PM
b1mcp's Avatar
Wheel sensor issues will not set the Engine Mgmt Light but they will set the ABS light. Is it definitely the Engine Mgmt Light that is on?
EZDriver (02-23-2018)
Old 02-23-2018, 04:48 AM
Qvhk's Avatar
Agreed with b1mcp. Are there any other symptoms other than the Check Engine Light? What diagnostic tools did the mechanic use?
Old 02-23-2018, 10:17 AM
EZDriver's Avatar
That is what I wanted to know. I wasn't sure if the ABS fault would set the check engine light or not. As far as I know the mechanic use a very good scan computer. I will go at it soon with my scanner. At least I can turn the light off and see if it returns. On my XK8 the ABS shows up on the center of the panel. Is it the same on the X300.
Thanks guy
Old 02-23-2018, 10:44 AM
Lady Penelope's Avatar
Received 1,387 Likes on 1,090 Posts
The ABS /TC will not reset until the car reaches 12.5 MPH and the X300 " ANTI - LOCK " and " TRAC OFF " fault light is in the pic below :
EZDriver (02-25-2018)
Old 02-23-2018, 10:49 AM
Qvhk's Avatar
Originally Posted by EZDriver
...... On my XK8 the ABS shows up on the center of the panel. Is it the same on the X300. Thanks guy
On the X300 the ABS (Anti-lock), Traction Control and Check Engine Lights are all on the left side of the panel. A modern scanner is unlikely to able to detect the fault codes of Jaguars of the 1995-1997 cohort accurately.
Old 02-23-2018, 04:17 PM
aholbro1's Avatar
Received 1,644 Likes on 1,069 Posts
Any OBDII-compliant device should read the code or codes responsible for the Check Eng. illumination.
WDS or other specialized equipment is required to read the other modules, responsible for Anti-Lock and such fault lights.
Old 02-24-2018, 06:56 AM
katar83's Avatar
Anti lock codes wont come up on a simple OBD scanner as far as I know, cheapest option for these is the Delphi diagnostic scanner from eBay. You can get these for ~$50 from eBay.
Reverend Sam
08-29-2021 10:47 AM
Cockbain
General Tech Help
07-17-2015 09:22 AM
Red October
02-09-2015 06:32 AM
Innovative Detailing
Detailing / Car care
12-06-2010 05:02 AM
tvstarmaker
06-08-2010 12:46 PM
Quick Reply: Wheel Sensors
