Where to find parts
ECU connectors corrosion check ?
From what I have seen the placard faces you as module installed
Search Genuine Engine Management Control Module Parts For Jaguar Xj 1995 - 1997 (from 720125 To 812255) (x300) Classic | Jaguar Land Rover Classic Parts
Parker 7 (09-24-2024)
The TPS reset ( called ECU orientation to tune " to " the TPS and O2 sensors ) is the matching by electronically tweaking ( highly special equipment ) the ECU to the currently installed TPS and it's fine performance ( idle mechanical stop reading or null ) very effecting your idle
It is the luck of the draw to drop in a replacement ECU and the current TPS " match "
For that reason , I recommend to not remove or adjust the TPS until getting a better understanding of the ECU to TPS relationship , but see how it works out with a replacement ECU and get back
The X300 ECU has been internally ( boards and devices ) and both connector halves repaired by owners themselves and the ECU case side connectors are avail as a TE Connectivity brand ( Econoseal series III 070 size 36 Way / pin )
There are also X300 ECU repair shop sources
Hi Vee , here is a red one as a TE part # 344111-5
36 Way TE Connectivity Econoseal Female Red - automotiveconnectors.com
Look for a R - 493 sticker on your ECU and the replacement and the engine compartment as a mater to discuss as a separate chapter from core ECU replacement for water damage
I like the Cat Brain title as someone else's work ( Katar83 , Luke ) and contributions to keep your Jaguar purring
Cat brain surgery - Jaguar Forums - Jaguar Enthusiasts Forum
Low melting point liquid solder ( different from cleaning flux or conductive adhesive ) with an low temp air heat gun ( easy and easily excess amount controllable )
Liquid solder is avail from my local huge electronics supply store , will have to take a pic of my brand
Electronic Supply - Kansas City, Mo. (eskc.com)
