where is my fan relay?
Old 04-22-2009, 01:14 PM
newquaymarc's Avatar
Default where is my fan relay?
hi all
im trying to find the relay that controls the radiator fans
tech info says front left,
but i cant find it
is it underneath?
cheers
Old 04-22-2009, 03:53 PM
panchostatus's Avatar
its behind the front left turn signal, should be a large white relay, larger than all the other relays, its tucked up under there, you have to go at it from under the bumper, if you have that plastic dust cover under your bumper you will have to remove it.
-pancho
hoodun
11-20-2022 02:35 PM
jagent
06-05-2022 02:18 PM
Seth
11-01-2015 12:17 PM
emilime75
XJ XJ12 ( X305 )
10-19-2015 09:55 PM
Quick Reply: where is my fan relay?
