Wiper not working
Hi
I have an xj6 1995 x300, and the wiper is not working, I have looked at every single fuse, I have swaped relays around, ( i still might need to look at the relays again though).
I have changed the wiper stalk, and also changed the motor.
I ran an earth and negative to the motor and found that the original did not work, and the new second hand one did, but this still did not fix my problem.
can any one help me please as i need it for mot lol.
Thank you
Thank you
The system is composed of the wiper arm switch, Body porcessor Module, on/off relay, high/low relay and the wiper motor. The 2 relays are under the hood by the air filter. There are two row between the fender and air box. They are the last 2 closed to the window and closes to the air box and not the fender.
thank you mate, but i cant see the pic lol, it says i dont have acsess, cant donate till the misses comes back lol.
the two relays that are near the air box on the passenger side, i have swapped them with the other two that are next to them and there was no difference.
should i start looking at this Body processor Module, and if i was to get a second hand one, would i need to get it programed in.
I think you need to post like 7 times to be able to see pics and PM people. The relays are in series, so if you swap them you might still get the same output or no power. If your fogs lights work, try swapn the relay closest to the bumper and fender side. I have in the passed tested relays with a 12V source and a voltmeter. I don't know if you have to reprogram a BPM.
philwarner
09-05-2015 10:05 AM
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
