I have a question regarding the Wishbone tie (MNA2850AB)
On the picture i have add, you can see the underside of the differential with the Wishbone tie connected. When the car is jacked and the wheels are off the ground i can freely move my left wheel and I can see that the bushing inside the wishbone is causing the trouble..
First question, are there replacement bushings for it? I cant seem to find any. If not and i have to order a new wishbone tie can i place the one with rollbar without any struggle or do i need some other parts also then? ( my parts guy only has one with rollbar in store )
Second question, can i just unbolt the wishbone and bolt on a new one or do i have to remove the complete suspension assembly?
