Hi
As a very new member and not even having collected the car yet, one item I know I need is a throttle pedal rubber. Can’t imagine why it’s not there but :
Where would I find one?
Is it compatible with many other vehicles.
can anyone send me a pic of what it should look like?
Hope someone can advise.
thanks
B
I can't speak for the 1995 Daimler 6, but my 97 VDP has a molded plastic pedal with no rubber as shown in the photo. The brake pedal does have a rubber pad though.
Hi
I managed to find a pedal rubber in the UK, based on the info you supplied, it looks right. Anyway let’s see.
Am I right in assuming that in most respects, the Daimler six and double 6 conform to X300 specifications for parts etc, just the trim level that differs.
I managed to find an original brochure from 1995, for the D6 and Double 6, and there is a discrepancy on the body length from some info sheets to another. Brochure says it’s 502 cm overall, but some specs say 512cm.
Perhaps they are the LWB.
B
Yes, for the most part the Daimlers will have more standard equipment and fewer optional things than a corresponding market Jaguar. Mechanically they will be the same. You will see variances in different markets too, for example the Daimler trim is basically the same as a Jaguar Vanden Plas in North America, but even there, there are differences between a USA market VDP and a Canadian VDP.
Hi
Thanks to all, I received the pedal pad from Norman Motors in UK. It’s hard plastic and slides on perfect.Unfortunately it was his last one. Nice guy very helpful, Only £14. well pleased.
B
