x300 1995
Rydale Key (02-25-2021)
THANKS FOR YOUR SUGESTION ROSS IHAVE TAKEN THE TANK OUT TODAY AND REMOVED THE PUMP AND TESTED IT IN A BOWL OF FUEL IT WAS PUMPING VERY WELL I REPLACED ITALL AND THEN CRANKED THE ENGINE OVER AND GUESS WHAT ITSTILL WOULDENT START SO AT LEAST I KNOW THE PUMP IS OK HOWEVER I WOULD APPRICATE ANY MORE TIPS LIKE WHERE IS THE PUMP RELAY SITUATED ARE THERE ANY HIDDEN IN LINE FUSES OR IN LINE FILTERS THANKS AGAIN FOR YOUR HELP I DONT FEEL QUITE SO ALONE WITH MY NO START PROBLEM
![Icon Doh](https://www.jaguarforums.com/forum/images/smilies/icon_doh.gif)
Do what I suggested originally and check if you're getting power down at the pump harness. You know the pump is good...so if you're getting power down to the pump as well then you know your problem isn't with fuel delivery (unless you have a VERY plugged up fuel filter).
3 major things you need for a vehicle to start and run...fuel, spark, and compression. Find out which you're lacking and we can help you further from there.
Hi I know i am several years after the first problem, but i too have a problem with starting x300 1994
My car cranks very well but wont fire 'check engine' warning light
i systematically swapped out the black relays in the engine bay , and then the blue ones in the boot even the black '423' one in the boot, car still wont fire.
Called the break down guy he squirted 'easy start' in the air line and car started but as soon as the turn off the ignition the car stops and wont start.
I bought a draper obd2 reader and gave error p1177 something to do with the fuel or maybe pressure..
Does anyone have anymore info on which relays need to be swapped
I read you checked ALL the relays ! At the advice of a forum member he advised me to check the 4 black relays on the passenger side (USA models) behind the headlight in the engine compartment. I think one is for the ECU, this one was my no starting/stalling problem on my 95 6cyl. I forget which one of the four it is but they are all interchangeable in order to switch around. . Also one is for the wipers. Don't know what the other two do. Anyway MAYBE this will send you in the right direction .
Lawrence
Lawrence
[WTB] X300 Canadian BPM
280zx-turbo
09-28-2015 04:37 AM
FS[MidAtlantic]: 1997 XJ6 VDP $3,900 - Very RARE Anthracite on Warm Charcoal
42Ajd
09-26-2015 07:04 PM
