x300 6 cylinder
The following 2 users liked this post by countyjag:
al_roethlisberger (05-08-2017),
Don B (05-09-2017)
The following 2 users liked this post by Jagboi64:
Don B (05-09-2017)
If it is output shaft bearings, they can be removed in-place, you don't need to remove the drive shaft to do that.
Or do we have a terminology mismatch? When you say drive shaft I'm thinking what's between the transmission and differential. Are you thinking of the halfshafts that go from the differential out to the wheel hubs?
If so, the best way I found was a thinwall 11/16" socket ( 6 point preferably) and long extension. You'll have to rotate the joint to get the best fit, but it doesn't fit perfectly. Then hammer the socket/extensions onto the nut and then use an impact wrench to get them out. The nuts are self locking, so impact the the easiest way to get them out.
The nuts and bolts on the driveshaft flange I have been able to get out with impact quite easily. Mind you, I bought a battery powered Milwaukee impact wrench that does 1100 ft-lbs. Way stronger than my air powered impact wrench, it can move just about anything. It would make short work of those nuts! One of the best tools I have ever bought.
Don B (05-09-2017)
How to rebuild the output shafts:
Welcome to Jag-lovers - Members Photo Viewing Page
Coupling replacement: Welcome to Jag-lovers - Members Photo Viewing Page
Don B (05-09-2017)
