X300 ABS C1095 DTC fault.
Pulled the ABS module off yesterday, as I've had the C1095 code since I bought the car. In fact, just less than a year ago, I took it (the car) by Bob's and we plugged the module he repaired (shown above) into my car electrically and hooked up the WDS and it was code-free, thus confirming both his fix of that module and my C1095 being the board not the pump in one fell swoop, or so I was convinced.
Now the problem: After cutting the module open, I find that I have continuity between the points connected by red lines in the following photo:
![](http://i1238.photobucket.com/albums/ff498/holbrz1/VDP%20Mechanicals/ABSContinuity.jpg)
which is a blow-up from here:
![](http://i1238.photobucket.com/albums/ff498/holbrz1/VDP%20Mechanicals/IMG_20110925_142459.jpg)
To my feeble mind, this tells me that I need to look further for the problem, no? I have also reviewed XJRGuy's helpful tutorial here:
http://www.mediafire.com/?rmwfpdxc7jgnbnm
I have also checked both ends of each connector pin (board side and connector side) for continuity across the pin (I know! but one can never be too sure) then from tip of the board-side of the pin to the areas as marked. It is the pin for the brown wire that is connected to the foil, and the red wire that is connected to the surface-mount component. Is this conitnuity the way it should be? I could imagine if a solder crack, I may have intermittent contact...but I've never had an intermittent ABS light, it comes on at about 200 yds of travel after startup like clockwork (eh....maybe a poor metaphor in this case...but already had THAT module repaired by ModuleMasters) and stays on until shutdown.
SO...should I have left my meter in the drawer and just smeared some solder on the two pins?
Here's one showing the dissection:
![](http://i1238.photobucket.com/albums/ff498/holbrz1/VDP%20Mechanicals/IMG_20110924_192158.jpg)
Oopsies! I made some sub-folders on photobucket under my "VDP Mechanicals" about 6 mo. ago or so...and on occasion when I'm in there, I'll move some into the appropriate sub-folder - found these under "Brakes" (wonder how many other previous posts I've screwed up?)
I'll see if I can correct the links..
https://www.myotherdrive.com/dyn/fil...ABS+Repair.pdf
I made this a few years back, spells out the repair pretty well.
Good luck!
aholbro1 (05-04-2014)
Thanks Steve, I recall reviewing that one when mending mine. I'd suggest if one has the patience for it, repeatedly scoring the groove with a utility knife until one gets through results in significantly less clean-up and perhaps reduced chance of getting into the board and damaging something. Of course, one needs a vise or suitable clamping arrangement to do it safely and successfully.
I got an anti-lock light on the way to work, middle of last week. Normally, I subscribe to the "read the codes" theory and mend the offending part rather than throw part substitutions at a problem. However, in this case, last Saturday morning having decided to remove the bonnet for liner mending on a whim, I recognized I could pull the ABS module, crack it open and solder the motor pins while I was waiting for the liner adhesive to cure, rather than bug Motorcarman for a Saturday WDS hookup.
So I dived in. First observation, as you may expect, the module is SOoooo much easier to open the second time! Sliced thru the permatex all around the perimeter with a utility knife and prised the cover off from the bits of permatex still holding the fixing-screw holes.
For those who haven't had the pleasure, a 13 mm hex for loosening 2 nuts below the pump motor in the front, and one in the back, next to the firewall. If second time, like mine..the pump/module will spring up and forward 6" or so from where you bent the brake lines the previous time. This time, you just have to tweak it a little farther forward and inboard to access the two torx on the bottom of the module fixing it to the pump.
You will need to disconnect the 2-wire pump motor electrical connector. I wait until the module is free of the pump to disconnect the multi-wire connector from the module using a 10mm socket.
Reverse all steps for installation.
I saw what appeared to be a crack or at least some space all around one post. I soldered both, for good measure.
Taped it up for a test and it checked good, no Anti-lock light within the first few hundred yards so I reckon it would've returned a C1095 if I had taken it to Bob for a reading.
![Name: IMG_20150927_134945494_HDR_zps2zeouyg0.jpg
Size: 248.0 KB](https://www.jaguarforums.com/forum/attachments/xj-xj6-xjr6-x300-26/153608d1501207706-x300-abs-c1095-dtc-fault-img_20150927_134945494_hdr_zps2zeouyg0.jpg)
![Name: IMG_20150927_134719376_zpsrrixwcrl.jpg
Size: 176.3 KB](https://www.jaguarforums.com/forum/attachments/xj-xj6-xjr6-x300-26/153609d1501207706-x300-abs-c1095-dtc-fault-img_20150927_134719376_zpsrrixwcrl.jpg)
The three fixing nuts will slide off:
![Name: IMG_20150927_134704616_zpsv1duq3lw.jpg
Size: 194.5 KB](https://www.jaguarforums.com/forum/attachments/xj-xj6-xjr6-x300-26/153610d1501207706-x300-abs-c1095-dtc-fault-img_20150927_134704616_zpsv1duq3lw.jpg)
Here the module fasteners are out and it is up/forward/inboard about as much as you need to access them. I didn't seat the module fully to the pump so you can see the interface to the pins:
![Name: IMG_20150927_134326484_HDR_zps6oqoqjn0.jpg
Size: 241.2 KB](https://www.jaguarforums.com/forum/attachments/xj-xj6-xjr6-x300-26/153611d1501207706-x300-abs-c1095-dtc-fault-img_20150927_134326484_hdr_zps6oqoqjn0.jpg)
I prefer to wrestle this mondo-connector on/off with the module freed from the pump:
![Name: IMG_20150927_134259169_HDR_zpsqp0unwfm.jpg
Size: 248.1 KB](https://www.jaguarforums.com/forum/attachments/xj-xj6-xjr6-x300-26/153612d1501207706-x300-abs-c1095-dtc-fault-img_20150927_134259169_hdr_zpsqp0unwfm.jpg)
I clamped it up overnight after re-sealing all around:
![Name: IMG_20150927_134004470_zpsky4qvfyx.jpg
Size: 301.6 KB](https://www.jaguarforums.com/forum/attachments/xj-xj6-xjr6-x300-26/153613d1501207706-x300-abs-c1095-dtc-fault-img_20150927_134004470_zpsky4qvfyx.jpg)
Here's a fair shot of where you have to get the pump to if you are using the "bend the brake-lines" method rather than disconnecting them and then doing an arduous bleed:
![Name: IMG_20150927_133937934_HDR_zpske5pslvz.jpg
Size: 267.6 KB](https://www.jaguarforums.com/forum/attachments/xj-xj6-xjr6-x300-26/153614d1501207706-x300-abs-c1095-dtc-fault-img_20150927_133937934_hdr_zpske5pslvz.jpg)
I just did this fix this past weekend! I didn't bend the brake lines like aholbro1 did, but I kind of wish I had. I just flexed the ABS module enough that I could fit a hand and tiny rachet under, like in these instructions:
https://www.jaguarforums.com/forum/x...removal-85123/
Getting those Torx bolts out, and then back in again, was extremely difficult, but my ABS light is gone!
sparkenzap (10-05-2015)
Hi
Thank you for the detailed and very timely post!
Our car has both ABS and Traction fail lights on
The diagnosis showed a 1095 fault apparently together with another code (which the guy cant remember) on my 1996 XJR 300. He referred to the activator, very confusing. His bottom line was that the ABS motor needed reconditioning. I searched and couldn't find anybody that repaired motors. I look forward to your thoughts.
thanks Charlie
thanks Charlie
#28
Thanks for digging up my post from 6 years ago. I forgot I posted this.
I have never replaced a motor assy. I suspect that one could fail but the modules are nearly always the culprit.
The other fault is likely the position sensor for the Trac Control.
Sort the bad solder joints out first.
bob
bob
#30
bob
bob
Many thanks
#31
You need to read the DTCs to determine what fault you have or you will just be guessing.
You can throw parts at the car but that gets expensive REAL FAST.
There are 2 position sensors. One is the throttle position sensor on throttle body and the other is the TC actuator sensor on the TC unit.
There are many reasons to have ABS faults.
Here is the DTC guide.
bob
bob
charlie.p (11-22-2016)
goges
10-05-2015 04:53 PM
FS[NorthWest]: 2004 X-type 3.0 24,500miles! $8500
millertic
09-30-2015 08:11 PM
