X300 engine problem
The only other two options I can recommend; check the pressure in the fuel pump and last but not least go to an auto repair shop and put it on a systems scope. The systems scope will will save you a lot of time and maybe some money because the scope will direct you straight to the problem. If you decide to go with system scope make sure you go to a repair shop you trust, because if they are not your friend it could be a $5 problem and they tell you its $500.
BrentGardner
28
04-26-2024 03:08 AM
