X300: How to change door handle seal ?
If I recall on mine there is enough room and angle from the inside for 2 fasteners either torx bit or allen heads fwd and aft on the handles
these fasteners have a special shaped washers that have to be oriented correctly to hold the door handle
Maybe a heavy all purpose grease to glue washers in position
Are you satisfied with the quality of the new seals and your vendor source ?
rrgoldstein
07-28-2009 09:00 AM
