X300 Power Steering not strong enough when idling
The tie-rod-end should come off when the bolt is removed from the outer end of the tie rod - the part the connects the tie rod to the hub/spindle.
Now, you may need to use a tie-rod-puller tool or a "fork" style tool to separate the tie-rod-end from the hub spindle.
Before taking them off, put some white paint or something on the threads of the steering rack shaft to show where the tie-rod-end comes to when reassembling. That way, you're at least close enough to the correct spot to be able to drive it to an alignment shop.
Thank you for your reply.
That bolt was the problem. I ended up giving it a few wacks with a hammer; that loosened it up. Everything came apart after that pretty quickly.
I do have a question though: the inner tie rods seem to fine but in order to remove them from the rack's core, I had to use a centre punch to destroy their locks (the lock was just an indent that prevented each inner tie rod from unscrewing on its own).
I might be able to use the centre punch to make an indent to make a lock again, should I or should I just replace them with new tie rods?
Best.
Best.
As an update, I flushed removed the old fluid from the reservoir with a pump a couple of time with Amsoil transmission fluid and the car no longer has this issue. I didn't even think about the fact that my fluid could be old and just this little bit of freshening of the fluid helped a ton. I really need to keep doing this but am saving the four quarts I have left for a transmission drain & fill at the moment.
aholbro1
08-05-2021 05:02 AM
Dicque
09-19-2015 12:53 PM
1964Daimler
09-09-2015 11:28 AM
