X300 Rear Axle Universal Joints
Old 04-07-2016, 07:37 AM
EZDriver's Avatar
Smile X300 Rear Axle Universal Joints
Just wondering if any one has had trouble with the universal joints in the rear drive assembly.
Old 03-01-2017, 02:02 PM
RFXJ12's Avatar
Picked up a 96 VPD that the drivers, outboard joint had failed. Tire moved nearly 2 inches if you pushed on it while in the air. Found it easier to pickup a used half-shaft and swap it out rather than replace u-joints. Didn't mess with wheel bearing either as all seemed tight.
MK2
10-11-2016 07:55 AM
jryall
XJ40 ( XJ81 )
10-11-2016 04:20 AM
kg7657
10-07-2016 02:25 PM
03-30-2007 10:29 PM
Quick Reply: X300 Rear Axle Universal Joints
