X300 Rear brakes
I just took the rear brakes apart - not really complicated at all!
The caliper is typical and fastened with two bolts while the disc is a "combination" rotor/drum affair with a small set of shoes inside for the parking brake. A large phillips head screw secures the disc to the hub. After removing it, the drum can be eased off the and the shoes inspected or replaced, if necessary.
Although it had been some time since I had to deal with ANY brake shoes, I remembered the arrangement and was able to disassemble and reassemble them from memory.
Main point to remember - don't forget to release the parking brake if you're gonna try and remove the drum!
Larry
Larry
The following 3 users liked this post by Lawrence:
The parking brake (shoe system) is "old-school" - cable operated and totally independent from the hydraulic brakes. One system can be serviced without affecting the other.
BTW, those rear shoes last a really long time unless you forget to release the parking brake and drive around with it still on!
cheers
Larry
cheers
Larry
oldish git
27
07-24-2020 02:05 PM
FS[Western US]: Parting out 1997 XK8 convertible
BobRoy
49
09-18-2016 10:48 AM
