X300 rear hub greasing, yes or no????
Since this X300 is the first "modern" Jag I have owned, old habits die hard.
I have always greased the rear hubs via the tin cap thingy, but this car has the ABS sensors in that hole.
I have searched a fair bit, but nothing answers the question, yet.
Do I remove the sensors, insert the grease gun, and merrily pump away, OR, is the grease going to bugga something up in the sensor area???.
I do not have any issues, just doing my "normal" maintenence thing. A rear wheel bearing failure from NOT greasing it is just silly in my opinion.
MMMMM, sounds like a plan, then I realised that is the screw that holds the sensor in place, and is further away from the bearing than the sensor.
Obviously they are well packed in the factory????, unlike the earlier system, which I have often found quite dry, but at least they can be greased.
Thanks anyway, and one day I will dissmantle it and do both areas as you suggest.
Richard_gib
09-12-2015 07:08 PM
innzane
09-02-2015 10:08 AM
