X300 Rear shock mounts
![Smile](https://www.jaguarforums.com/forum/images/icons/icon7.gif)
Hello to one and all,
I am gathering parts for replacing my rear shocks and any other parts needed. I see at Rock auto that there is a coil spring insulator offered. I suppose this is needed with the new Bilstein shocks. Years ago I had this done and I remember that there was a rubber pad that went underneath the edge of the mounting cup that supported the top of the shocks up in the frame. Is this spring insulator that part?
Thanks guys.
Thanks guys.
Received 13,204 Likes
Part 5 in the diagram below is the large foam rubber spring isolator or "donut," and it will not come with your Bilstein shocks so you'll definitely want to order a pair.
You may want to confirm that your new shocks will come with the lower bushings, Part 17. If not, you will want to order those also.
You will also need the smaller foam rubber isolator bushes, Parts 13 and 14, but it is likely that they will be included with your shocks - just confirm with the vendor.
You can look up part numbers at this link:
Damper and Spring Fittings-Rear - Parts For XJ Series from (V)720125 to (V)812255 (X300) | Jaguar Heritage Parts UK
![](https://cimg1.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/400x509/sh6011a_5238001932d98cb367eea5d39696edca1569b693.png)
I have photos of the rear shock job on our '93 XJ40, which is very similar to the X300 with the exception of an additional rubber bushing at the top and a fixed lower shock bushing:
Welcome to Jag-lovers - Members Photo Viewing Page
Cheers,
Don
The following 3 users liked this post by Don B:
The Bilsteins come with everything assembled as the part #7 group.
When I replaced my shocks, I also replaced parts 4 and 5. 5 was an absolute requirement after almost 20 years, and 4 turned out to be fine. But I did it just in case I damaged the originals removing/installing the springs.
The following 4 users liked this post by al_roethlisberger:
No problem, I obsessed over this too before replacing mine since I knew it was a PITAsteroid job
I didn't want to miss something and have to do it again.
.... so I try to help when others are trying to figure it all out prior too.
Recent feedback also seems to indicate the "A frame drop" method is easier...
Good luck!
Good luck!
The following 3 users liked this post by al_roethlisberger:
KarimPA
09-12-2015 08:15 AM
OkieTim
09-08-2015 04:48 PM
Tar
09-06-2015 11:24 AM
