x300 ride height
Received 10,988 Likes
It's been some time .....but the only ride height spec I recall in the X300 manuals was in the wheel alignment section and was 150-155mm clearance from the bottom of the subframe to the ground....front and/or rear.
The only reason I recall it is because of the rather amusing text. The spec for several build configurations was given (all within the 150-155mm range as I recall) with a bit of a finger-wag that you must ensure the car sits at the specified height before alignment. Then, in the very next breath, we're told that if an ** XJR ** is not within the listed specifications, no worries.....just go ahead and perform the alignment at whatever height the car is presently resting at!
There may well be other specs in the manual which make more sense but I might've missed 'em....or forgotten
someguywithajag (08-07-2018)
