X300 TPS Installation, help please.... FIXED
what is it "dvom", where I should get 0.6 volt, on which wire? I will change my sensor soon, but how setup right? can you explained please about 0.6 volts?
you dont need IDS or to go to the dealer. You pin the signal wires with a dvom and turn it(the TPS) to get a .6volt reading at idle. And yes you dont need the engine running or the throttle body on the car. Just the sensor hooked up and the key on, and throttle at the idle position. You can turn the TB over to access it easier
I took the throttle body of but kept the sensor plugged in. Vice gripped the coolant line on the front side as well. Then I put a paperclip into the back of the middle of the three wires. Grounded to the manifold with clamps on both end so I could adjust the TPS and fixing screws until I fined tuned and tightened. I manually loosened the two screws holding the TPS on an there is PLENTY of play to adjust to .6V at rest. It took me a minute to get the two screws tighten up at exactly without throwing off the reading, especially since one of mine is stripped and I had to use small vice grips on it.
Kinda fun, I've never been electrical all at but after this post and few others peppered in, I fixed my own car, again, it feels good. I know now I never need to go pay for IDS access for this issue at least. 02 orientation is another story.
![Icon Dance Cpatch](https://www.jaguarforums.com/forum/images/smilies/icon_dance-cpatch.gif)
al_roethlisberger (06-11-2016)
THIS SAVED MY BUTTOCKS. I was chasing down a fuel trim/low pwr issue for months. My throttle cable has a bit too much slack and when I was adjusting it I think I threw off the throttle blade at rest from there and it all went down hill. I even had the IDS reset twice by an independent Jaguar guy for $40 but to no avail.
Can you more clearly explain how your connected your pins to the back of the TPS connector, which pin was grounded and where the digital multi meter was connected?
Al, I tested all three ports from the back side, I had paperclips going thru the back of each of them. I realized when measuring, that the middle one is your signal wire.
I straightened one end of paper clip and inserted it into the backside of the retaining clip until I could tell it was past the insulation. Then I clipped my red terminal to the rest of the paper clip. For the black terminal I used the front of the intake manifold where it is thin enough to attach the clip to. I found when testing that I got better ground there than the ground located below the air filter, behind the headlight or clipped to the ground on the far left of the drivers (US) side bulkhead behind the hood catch.
aholbro1
08-05-2021 05:02 AM
kevo
09-08-2015 09:45 AM
