X300 type of power steering fluid
I am in the process of changing the power steering fluid. It has been recommended the I use synthetic fluid. The only synthetic I can find is Valvoline ATF Dexron-VI Full Synthetic. Does any one see a problem with using automatic fluid in the power steering system? I have not used synthetic in the system before. Any one see a problem with mixing the types until I am able to get a complete change?
Thanks guys.
Thanks guys.
The following 2 users liked this post by EZDriver:
Grant Francis (11-23-2015),
MikeyB10 (12-18-2019)
The following 3 users liked this post by motorcarman:
Thanks Bob.
I had to hunt down that S Type fluid for the Black Beast, and down here it was a PAIN, but all good now. I suspect it had ATF in it, as it was juddery when first owned by me, now sweet as, and it took 8 suck and refills without going too low and getting air in the damn thing, HA.
Now I typed that I might just give it another suck and refill tomorrow morning, coz I can.
My minor then later tremendous return line leak last year helped me fully flush mine out over a few months
I used Valvoline Dexron 6 synthetic ATF because that's what I had. Worked fine.
Although it is possible, I doubt the steering pump and rack has the same potential sensitivity to the difference between Dexron 4 and 6 as a transmission might.
Dean9785
03-21-2016 08:21 AM
Ymss845
10-26-2015 01:16 PM
